LG F1289TD5 LE Error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG F1289TD5 LE Error code
  • #98595
    MajorCakey
    Total noob posting here!
    I have the machine mentioned in the subject which threw the above error code at me, upon closer inspection it’s a problem with the drum turning, to spin it by hand it is not free, and occasionally locks up to the point where it requires a really stiff push to get it to turn again, there doesn’t appear to be any nasty sounds when it does turn, and it hasn’t skipped a beat in the 7 years we have had it, up to now! Any advice or help would be greatly appreciated, as I need to make a decision on whether to replace it or not.
    Thanks in advance!
    #472985
    is there something trapped between the drums like a sock or bigger
    MajorCakey
    I am swaying towards think that, but can’t see nothing, I have even taken the top off and checked through the inlet to see if I could spot anything, but to no avail, maybe I need to strip it down a bit more to get a proper look?
    #472987
    what i nomally do is get a torch inside the drum and look through the holes to see if i can see anything
