I have a 3 year old LG washing machine. It has started to make a noise like angry wasps in the machine when it is on the wash part of the cycle. I have cleaned out the filter. Has anyone had the same problem? Any suggestions as to what the problem might be.
If you have a little yellow plastic jet inside the top part your door seal. They can clog up with fluff and all sorts that runs on a recirculating pump. If this is blocked up it puts pressure on the pump and make that type of sound. Try to clear this and that may sort it.
leedata1979, sir you are a genius, my once quiet washing machine is now perfectly silent again. Many many thanks for your advice! You have earned yourself a large drink. Genius sir genius!!!!
Murtle65 xxxx
