Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LG F1403RD Washer/Dryer really noisey spin help needed
- This topic has 13 replies, 3 voices, and was last updated 12 years, 6 months ago by
silverdale.
September 18, 2013 at 6:20 am #77201
silverdale
ParticipantIve had the LG F1403RD from new about 30 month and its just started making a shocking noise when on spin.
I’ve levelled it up perfect but still makes this bad noise . I took a video ;-
http://www.youtube.com/watch?v=WBA8Gv1b … e=youtu.be
the video doesn’t do it justice , it’s actually alot worse than it sounds when live !.
About a week back , when opening the door to empty it I found a large brown elastic band type thing hanging down between the drum and the large grey rubber seal. It snapped away into 2 pieces but for the love of me I cant find were its come from
Does anyone know why its making such a bad noise ? I use to be able to set it to wash through the night but its that noisey we can here it upstairs.
I’m more than willing to sort the matter out myself if it’s a case of a simple part replacement or screw down something loose so any help would be greatly appreciated .
September 18, 2013 at 7:12 am #401368Martin
ParticipantRe: LG F1403RD Washer/Dryer really noisey spin help needed
silverdale wrote:I’m more than willing to sort the matter out myself if it’s a case of a simple part replacement or screw down something loose so any help would be greatly appreciated .
Drum Bearings by the sound of it. 🙁
September 18, 2013 at 8:47 am #401369silverdale
I have to confess to trying to repair the rubber outlet drainage pipe a couple of weeks ago .While trying to level the washer up I dragged it out and the plastic drainage hose took a tiny nick in it leaking water onto the floor when draining (the rubber protector that protects the house from the sharp metal of the washer had come loose.
I did flip the washer on its side thinking I could access the hose from underneath but it was then I realized to change the hose meant a strip down so I fixed the nick with a soldering iron melting the hole and sealing it.
so could me flipping it on its side cause the washer to become unbalanced ?September 18, 2013 at 11:31 am #401370Martin
silverdale wrote:so could me flipping it on its side cause the washer to become unbalanced ?
Can’t rule it out but you stated earlier that it was level. The video didn’t indicate vibration either as the machines cabinet appeared perfectly stable. The noise sounded more like ball race bearings grinding TBH.
September 18, 2013 at 3:27 pm #401371BobHope
please stop using your appliance as more damage will be done, the fault is the dryer housing has broken away from the tub assembly, it may be repairable without parts if has just started to be noisy.
Bob.
September 18, 2013 at 5:44 pm #401372silverdale
So is that the rubber band thing that was hanging down ? . Is it a job a compedant diy’er like myself can tackle ? And lastly..do you have a link to the correct replacement part ? . N cheers Bob for that 🙂
September 18, 2013 at 6:37 pm #401373BobHope
it all depends if the bolts and screws have just come loose or are the mounting luggs broken off.
Bob.
September 18, 2013 at 7:29 pm #401374silverdale
so is it a full strip down to access the damaged dryer housing ?
September 19, 2013 at 6:17 am #401375BobHope
just a simple removal of the top covers.
Bob.
September 21, 2013 at 9:02 pm #401376silverdale
BobHope wrote:just a simple removal of the top covers.
Bob.
Hi Bob , do you happen to have any guides/video’s showing the removal of the covers ?.
thanks again.September 22, 2013 at 6:49 am #401377Martin
A video on ‘How to remove the lid on an LG’ now that WOULD be handy…….
September 22, 2013 at 10:15 am #401378silverdale
Martin wrote:A video on ‘How to remove the lid on an LG’ now that WOULD be handy…….
I dont know how to take that wether its a sarky remark or your in a similar boat as myself.
I’ve not a clue taking a washer apart hence why I asked. I asked just incase there’s hidden plastics clips and you end up tugging away not knowing till you snap them off. If it’s a case of a simple few screws then fine but I thought I’d just make sure.September 22, 2013 at 10:37 am #401379BobHope
to be honest silverdale if you cannot revove the top of the machine i would call in the local repair agent as the repair is not as easy as you think.
bob.
September 23, 2013 at 10:20 am #401380silverdale
BobHope wrote:to be honest silverdale if you cannot revove the top of the machine i would call in the local repair agent as the repair is not as easy as you think.
bob.
lol , like it Bob ,
I took the top off and you were bang on bob.Were the large housing for the dryer outlet is sat 3 screws had come loose. I found 2 of them in the washer which I retrieved with a long reach magnet. I found a similar one in the tool box but this time I used nylon and split washers to stop them coming loose.
Just tried the washer and it’s sounding far far better , purs like a ,,,,,,, er,, washer.
thanks for the advise Bob , much appreciated. -
