LG F1443KD6 recirc pump Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG F1443KD6 recirc pump This topic has 4 replies, 2 voices, and was last updated 11 years, 3 months ago by Johnnyboy. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts December 12, 2014 at 4:48 pm #83393 JohnnyboyParticipant first one of these, do you have to remove the entire front, or side or what to access the double pump assembly? its an 11kg washer. Cheers December 12, 2014 at 5:45 pm #422635 Andy jonesParticipant Re: LG F1443KD6 recirc pump Front off if it’s the same model as I done. Fairly simple job December 15, 2014 at 11:32 am #422636 JohnnyboyParticipant Re: LG F1443KD6 recirc pump are you sure? as the seal is stuck to the front and not removable like the normal models. December 15, 2014 at 8:14 pm #422637 Andy jonesParticipant Re: LG F1443KD6 recirc pump Can’t be certain on the model no. Seal is stuck ? December 16, 2014 at 5:18 pm #422638 JohnnyboyParticipant Re: LG F1443KD6 recirc pump yes ,its not held on by a retaining front spring its, sorta attached to the front. Not the usual 4 screws off,seal unclipped and it falls off type. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
