Machine starts to speed up then cuts out as if out of balance sensor is activating. This happens under any load! Drains out ok,bearings good. Wonder if shock absorbers are worn out,although machine is quite new? Not seen this build before,it has an independant fixed,what looks like a false tub,with the actual tub slung beneath it!
Faulty sensor,pcb??
