Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LG F1480TDS stops after 6 minutes and blows the rcd
- This topic has 9 replies, 3 voices, and was last updated 9 years, 6 months ago by
0adbylad.
September 23, 2016 at 2:08 am #89373
0adbylad
ParticipantHi….Ive just had this problem on my LG F1480TDS after about 6 mins it stops and trips the RCD,after a reset it will work just fine and do a brilliant wash
Anyone how can advise me please?September 23, 2016 at 7:41 am #441189electrofix
ModeratorRe: LG F1480TDS stops after 6 minutes and blows the rcd
my first guess would be the heater. 6 minutes is about right for the heater to switch on.
normally it would keep tripping if you reset but its still the first guess
if you set a rinse programme that does not heat does it still trip ?
you could disconnect the wires to the heater and insulate the connections ( after unplugging the machine )
then try the programme with the heater disconnected. Yes it wont heat and would take hours to go through the programme so dont add washing but if it does not trip you probably have found the problemDave
September 23, 2016 at 9:29 am #4411900adbylad
ParticipantRe: LG F1480TDS stops after 6 minutes and blows the rcd
Thanks for your reply Dave ill give it a try
September 23, 2016 at 9:36 am #4411910adbylad
Hi Dave ive just tried the machine on a cold rinse and no problem at all
So am i looking at a quick cheap fix?September 23, 2016 at 9:59 am #4411920adbylad
a quickie Dave just where is the heater element on this machine front or back
Thanks againSeptember 24, 2016 at 7:47 am #441193electrofix
think its on the back at least all LG machines i have seen are
dave
September 24, 2016 at 9:03 am #441194Lawrence
Concur with Dave ,it’s the element ,unplug ,back off and heater is at the bottom of the tub (6oclock)
September 24, 2016 at 12:03 pm #4411950adbylad
Ok guys thank
I took the back off and disconnected the heater,but the washer wont start up without a load 🙁 then it says UL error 🙁 so i figure it might be either the backs off or theses no load on the heater
Got my daughter to to come up who’s a qualified electrician and run her fluke multimeter on it
Bingo nothing
so ive just ordered the part now
Thank you once again one and all 🙂October 2, 2016 at 2:06 pm #4411960adbylad
Hi…Just drop by to give you an update
The part came eventually 🙂 fitting went ok machine tested out perfect
Thank you all
RobinOctober 2, 2016 at 3:54 pm #441197electrofix
glad to help M8
