Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › LG F1480YD5 – Wash Element support
- This topic has 6 replies, 2 voices, and was last updated 9 years, 10 months ago by
Hollytree_Technical.
June 8, 2016 at 1:08 pm #88506
Hollytree_Technical
ParticipantHi All
Went to fit a genuine new element to this unit today because the terminal had snapped off of the old one and found that it had been worn through on the drum, it is quite a long element and I can not see any form of holder/support for the front end so it wants to flip up and catch the drum, my suspicion is that there should be a metal bracket that it slides through mounted in the front half of the tub but I couldn’t find any remains of one and it doesn’t show on any parts diagram, the images that are available for the front half tub don’t seem to show this part although the odd one does.
Should it have a bracket and if so what is the part no that I need to order.
Thank you
Jem
June 8, 2016 at 1:27 pm #438384electrofix
ModeratorRe: LG F1480YD5 – Wash Element support
cant see any support on diagson connect even looked a drum pictures but cant see anything
is the spider ok ?
June 8, 2016 at 3:03 pm #438385Hollytree_Technical
ParticipantRe: LG F1480YD5 – Wash Element support
Drum spider and bearings are fine, the drum is running in the correct position.
If I press down gently on the terminals at the back of the element then you can feel and hear the front lift up and touch the drum – it’s such a long element that I cant believe that it would be unsupported.Jem
June 8, 2016 at 4:28 pm #438386electrofix
have you checked the sump hose dont know with LG but some of them are just a bent bit of wire small enough to land in the sump hose
June 8, 2016 at 4:30 pm #438387Hollytree_Technical
I stripped the sump and pump down but couldn’t find anything, from looking at the tub through the element hole I suspect that it should be a metal loop that goes round the element which would then be hooked under plastic tabs at each end but couldn’t find any traces of anything.
Jem
June 8, 2016 at 5:03 pm #438388electrofix
had a really good look on connect and could not see anything even on similar models. if you type in ” LG heater support” you get lots but no pictures and no models
June 13, 2016 at 7:07 pm #438389Hollytree_Technical
Anyone else able to help?
Jem
