It looks like I may have a similar issue to steeno69, however the symptoms are slightly different. Am getting an OE code when running a full wash or the clean cycle. Switching off and then running rinse/spin empties the machine as normal – no OE code. Running rinse/spin on it’s own and it empties correctly (every time) with no OE code. I have checked filter – clear, bottom of tub – no socks or other blockage, drainage tube and sink spigot – clear and no obvious obstruction if I blow down it. I can’t feel anything stuck in the impeller, but it is not easy to see. Any suggestions gratefully received.
Latest update: Drying cycle completes, but excess water prevented door being unlocked. Clothes came out steamy rather than dry.
