Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG F1495KDS – Suspension
- This topic has 4 replies, 2 voices, and was last updated 3 months, 3 weeks ago by
Hollytree_Technical.
December 10, 2025 at 11:19 pm #103703
Hollytree_Technical
ParticipantHi All
Quick question for you all, I have just replaced part of the outer tub on this machine for what I initially thought was an hole caused by an impact, after having a closer look at the old part I found several areas where it appears to have cracks from flexing (for example – both sides at the rear of the sides of the tank), my guess is that the machine flexes and twists slightly at times when it is going to spin and that this may be the cause. I decided to have a closer look at the suspension setup as the customer said that the drum always moved quite a bit and has chewed the inner edge of a couple of door seals pretty soon after fitting. I can see 2 dampers on the machine (1 either side) which I can see would reduce twisting or up and down movement but has no effect (as far as I can tell on back and forth), I also see 3 springs with legs – do any of these have dampers built into them or are they just springs?
Jem
December 11, 2025 at 3:38 pm #494248electrofix
Moderatorif its the one i think it is isnt there a damper at the rear ?
is it like this one ?
https://www.youtube.com/watch?v=V5pJvcYPZKQ
December 11, 2025 at 8:48 pm #494249Hollytree_Technical
ParticipantYes that looks like the system.
It has got one of these AGM72924807 shock absorbers at the rear but I don’t know if there is supposed to be a damper built into it or not. It also has a similar part (different part no) each side at the front along with a couple of traditional dampers.Jem
December 11, 2025 at 9:32 pm #494250electrofix
Moderatorhad to change the rear boot on one. That was real fun lol
only good thing is since the tub is fixed you can take all the sides off after undoing 1.3 million screws
December 11, 2025 at 9:34 pm #494251electrofix
ModeratorHollytree_Technical wrote:Yes that looks like the system.
there is a damper built into it see pics on Aswo
