Our LG washing machine keeps blowing the RCD! I have replaced the heating element today for a new one from here but it is still tripping. Whilst changing the elements I did notice some water in the creamy white plastic cover at the bottom of the machine.
Please can anyone advise on what else I should check ?
You will need a insulation tester to find the problem but I will hazard a guess at the filter coil pcb this is where the mains power inters the machine but to confirm this you need to test with insulation tester kai
