LG F14B8QDA Water issue.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG F14B8QDA Water issue.
  • #88265
    PaulH992
    Good evening,
    Hoping someone can help me here as my LG washing machine has an issue were the machine with fill with water almost 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} full and then get a iE error code. It seems like the machine is not sensing the water level and thinks it is not filling with water or filling slowly which is why it is getting the iE error code. Does anyone know how to fix this or if i need a new part what do i need?
    Thanks for the help in advance.
    #437527
    Re: LG F14B8QDA Water issue.
    there is a switch with a small tube coming off it at the top of the machine. this switch senses water level and uses air pressure to do it. if you follow the tube down you will find a plastic bell.
    if this bell is clogged or the tube has a hole rubbed through it it will cause your problem
    warning do not blow into the switch
