LG FH4U2VCN2 ie fault
  • #101440
    cornwell40
    Tested this washer and does the load dance for 2 minutes then aborts with ie showing. Checked valve solenoids, all ok. Doesn’t give any power to the valve at all before it aborts so I’m presuming a PCB fault which is discontinued. Any other possibilities which I’ve missed as I’m a bit lost on LG D.D stuff.:(
    Tony
    #484763
    tech info on these is almost non existant and changing a board, and your wrong, is a real pain not to mention costly
    check the machine pumps as on some machines an open circuit pump stop filling
    also check heater for earth faults, bit of a long shot but stranger things happen
    ianfraser
    Start with the door switch, then move onto drain pump. Then check all other components of the machine. Good luck
