LG Fridge Freezer
  • #19577
    DentedPorsche
    Hiyas,
    Got one of these on the go. Model is GR-S592QVC.
    Freezer is icing up and customer has to manually defrost.
    Defrost heater meters OK. There are two small components cable tied to
    the top left of the evaporator, near the heater element, and four wires running back to a 4 way plug.
    Any ideas on this fault? Can’t identify these components. Any ideas? Part numbers would be a bonus.
    Brian
    #183708
    Re: LG Fridge Freezer
    Hi Brian
    they are thermal overloads and defrost terminators.
    Bryan
    #183709
    DentedPorsche
    Thanks for that. I did say to technical that I thought they were a defrost sensor and thermal fuse so not far off the mark. Not sure which is which but one of them reads open circuit, and no idea if this is correct or not. They can’t find these parts on the LG schematics / web site.
    Would these components be the cause of the problem? I’m pretty sure this machine isn’t doing a defrost hence the build up of ice which eventually blocks cold air to the fridge section.
    I hate having to use best guess but I’ve no information whatsover on LG refrigeration so no way of getting part numbers myself, other than asking here 🙂
    Brian
    #183710
    whitevanman
    Check your email Brian
    #183711
    DentedPorsche
    Ta for that Wayne. All makes sense now and should be able to get the parts I want.
    Brian
