Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG Fridge freezer (Job No. 307085)
- This topic has 9 replies, 4 voices, and was last updated 17 years, 5 months ago by
dna.
October 18, 2008 at 1:42 pm #40309
dna
ParticipantGRS592QVC Has anyone come across this problem before. When you shut the fridge door the freezer door opens. I thought that this is ok due to the size of the fridge door it was causing updraft making the door open.
Lucky GoldstarOctober 19, 2008 at 10:16 am #265716ELDAR59
ParticipantRe: LG Fridge freezer (Job No. 307085)
try angling the fridge backwards slightly to encourage freezer door to close.
cheers.October 19, 2008 at 12:56 pm #265717dna
Hi it opens then shuts again. It only only about 1/2 inch
October 19, 2008 at 2:20 pm #265718ELDAR59
i wouldn’t worry about it then, unless the customer is concerned.
i’m not familiar with this model, but if you could adjust the hinges to increase the gap between the doors, that might help.
alternatively raise the front as mentioned. this does help the freezer door to go back.
it’s a fairly common problem, or perhaps with large doors, characteristic is the right word.October 19, 2008 at 4:04 pm #265719roly16
Presumably the fridge is cooled by air ducted up from the freezer. When you shut the fridge door you’re compressing the air which is forced into the freezer pushing the door open. Try shutting the fridge door slowly; that should stop it. I don’t think the size of the gap between the two doors is relevant.
October 19, 2008 at 4:11 pm #265720ELDAR59
hi geoff, i’ve known the size of the gap between the two doors to be a definate factor in displacing the freezer door. it’s the air gap between the two doors that causes the draught, which forces the door open.
widening the gap, if possible, could eradicate the problem.cheers.
October 19, 2008 at 4:51 pm #265721roly16
Not come across that myself but it’s always worth trying.
GeoffOctober 19, 2008 at 4:54 pm #265722ELDAR59
how are things geoff?
is it still shorts weather for you? 😆
cheers.
October 20, 2008 at 1:58 pm #265723expertcat
ParticipantThey had this problem a few years ago and solved it with a stronger magnet in the door seal.
This may be the answer if this crops up alot.
October 20, 2008 at 7:05 pm #265724roly16
alf_uckem wrote:how are things geoff?
cheers.
Not too bad under the cicumstances thank you, and yes, of course it is. 😀
