Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › lg fridge freezer over freezing
- This topic has 9 replies, 3 voices, and was last updated 14 years, 9 months ago by
timofleeds.
June 16, 2011 at 9:08 am #63398
timofleeds
ParticipantHi I have an LG fridge freezer ( freezer above fridge) It is over freezing in the fridge compartment. From reading various posts I think it needs either a new thermostat or new thermistor.
I can not find the part(s) I need, can anybody help?Model number is GR-322-3828JD8250K (taken from the instruction booklet) Unit is approx 6 years old) We bought it new.
Regards Tim
June 17, 2011 at 9:47 pm #353655kwatt
KeymasterRe: lg fridge freezer over freezing
Hi Tim,
Get the model number from the actual rating plate and I’ll try to track it down as best I can for you and have a look at the configuration if possible. Instruction books are not to be trusted.
June 18, 2011 at 11:42 am #353656timofleeds
ParticipantRe: lg fridge freezer over freezing
Hi K thanks for the reply, the fridge is in Spain so it will be the end of June before I can get the actual details. I hope this is ok.
Regards Tim
June 29, 2011 at 10:26 am #353657timofleeds
Hi K, i am now back from Spain and have got all the numbers from the plate at the rear of the machine.
GR-322W
3DRE2201
SER NO 312KR00237
BAR CODE NO 53678312002372201241I hope this helps,
Regards Tim
June 29, 2011 at 11:28 am #353658kwatt
Hi Tim,
Was that machine bought in Spain as there’s nothing coming up for it which wouldn’t be a shock if it was bought over there?
We often get this, some models are only sold in certain territories and, if that’s the case, you’d have to get spares locally for it.
June 29, 2011 at 11:40 am #353659timofleeds
HiK yes it was bought in Spain. If I take the parts off do you think I could get a match for the bits over here?
Tim
June 29, 2011 at 12:06 pm #353660kwatt
Mission impossible I’m afraid in most cases as, to us, it’s just a model number and part number and that’s the only way that you can identify most spares. If you can’t identify the part by part number you usually haven’t a chance unless it’s something really common.
Even if it was in stock somewhere and corresponds to a UK part, which is probable, the trouble is identifying the UK part number to get it.
June 29, 2011 at 12:12 pm #353661timofleeds
Hi K looks like a new machine then or put it on a timer. Many thanks for your help.
Tim
July 10, 2011 at 10:17 pm #353662QUICK FIX
WHERE ABOUTS IN SPAIN ARE YOU I KNOW OF THE LG SPARES IN ALICANTE ALSO TRY LGS WEBSITE IN SPAIN THINK THERE IS A TRANSLATION BIT AND YOU CAN TYPE IN YOUR MODEL YOU DO GET A GR3222
July 13, 2011 at 1:28 pm #353663timofleeds
Hi Quick fix, thanks for the info I am down near La Manga, not too far from Alicante. I will go on the website and see what I can find.
Many thanks Tim
