LG GR-L206CPQA
  • #88992
    stevebunyan
    Does any one have the part number for the internal water supply tube from the valve to the reservoir or failing that the diameter.
    #439985
    SAMURI
    Re: LG GR-L206CPQA
    Should be LGE5210JA3004A. Or connect part number 5031687876775.
    Common fault pipe starts to crumble and split anytime after 5 years old from the valve to the water tank due to the heat from the compressor.
    It is normally the same size pipe used on the water supply on LG American fridge freezers but the part number above is cut to the correct length.
    Bob
    #439986
    stevebunyan
    Re: LG GR-L206CPQA
    Thanks Bob
    Greatly appreciated.
