LG GR232SBFH
  • #24278
    Alanj
    Hi Guys,
    got to go to this call on Monday Frost free f/f.Customer complaint food freezing in fridge compartment. Any ideas on where to start looking? Thermistor?
    Alan
    #201418
    BobHope
    Re: LG GR232SBFH
    hi alanj,
    the fridge temprature is regulated by a simple damper assembly on this model, it is located in the fridge on the backwall, they go out of calabration or i have had one that had iced up.
    good luck.
    Bob.
    #201419
    Re: LG GR232SBFH
    Hi all
    there is also a fault code that will show up on the front display panel,if the freezer fan assembly fails the fridge compartment does also freeze in places.
    bryan
    #201420
    expertcat
    If its freezing the salad draws take the rear assembly off in fridge and make a new foam gasket and reassemble
    #201421
    Alanj
    Re: LG GR232SBFH
    Hi Guys,
    thanks for the replies.Will let you know how it goes.
    Alan
    #201422
    Alanj
    Re: LG GR232SBFH
    Hi Guys,
    wrong info on this one. Freezer working ok, fridge not cooling.This appliance is less than a month old and the evaporator is solid with ice build up, hence why the fridge is not cooling. Is there any particular place to start looking to cure this problem? Any help grateful.
    Alan
    #201423
    Alanj
    Re: LG GR232SBFH
    Hi Guys,
    has no one got an answer to my question? Freezer working but fridge not cold. Where do Ineed to look to start solving this problem?
    Alan
    #201424
    MC
    Re: LG GR232SBFH
    defrost the ice to give fridge the airflow from freezer to keep the cust. going. it sounds like the pcb board is at fault, like a lot of these frost free,s
    #201425
    roly16
    Re: LG GR232SBFH
    According to my diagram:
    Disconnect the brown wire from terminal 1 and the orange wire from terminal 2 of the defrost timer and check the continuity from the orange wire to neutral; this tests the defrost thermostat, heater and 77deg thermal fuse in series. Also make sure the timer is rotating. The evaporator will need to be cold for this test or the defrost stat will be open.
    If you need the diagram I can email it to you but am away till Wednesday.
    Geoff
    #201426
    Alanj
    Re: LG GR232SBFH
    Hi Geoff,
    would appreciate a copy of diagram when you return.
    Alan
    #201427
    roly16
    Re: LG GR232SBFH
    hi Alan,
    Sorry, got back into work Thurs instead of Wed but only just noticed the email advising me of your reply on this thread. I’ve got the manual for this model. What do you need? Anything apart from th e circuit diagram? Let me have your email address to send it to.
    Geoff
    #201428
    Alanj
    Re: LG GR232SBFH
    Hi Geoff,
    you will get my e-mail address by clicking e-mail in my profile.
    Alan
