Hi gents
been to above f/f replace water valve as was ko,now makin all rite sounds but still no water coming through water dispenser.could this just be a frozen pipe b4 i go back
regards
tony
is this the double door type ?? if so check inside the fridge compartment.. behind the pull out drawers the water gets cooled there…ive found that the fridge evaporator gets overiced which freezes the water cooler
remedy = defrost fridge evap and retest..
