LG GWB227YSAA Freezer Not Cooling – Frost on Evaporator
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum LG GWB227YSAA Freezer Not Cooling – Frost on Evaporator
  • #85003
    smandoob
    Hi all
    Further to my last post about my freezer not working (sorry – couldn’t add another reply to it for some reason), I have taken a picture of the actual frost build up on the evaporator.
    The only parts I can find for this fridge freezer is the evaporator on here. Can’t find the defrost sensor / fuse anywhere else otherwise I would try that.
    Given up on engineer call outs now as they are all too expensive and looking at getting another freezer after this!
    Any last help appreciated
    #427413
    SAMURI
    Re: LG GWB227YSAA Freezer Not Cooling – Frost on Evaporator
    If it only frost up on the pipe at the top and not evenly over the evaporator it looks like it might be a refrigerant or compressor fault.
    You need to check to see if the compressor is running hot.
    If it is then it is one of the above faults.
    Bob
    #427414
    smandoob
    The compressor is hot to touch yes Bob. I trust these two fixes are not for the fridge DIY novice though?
    #427415
    SAMURI
    It’s an engineer job if it is a refrigerant fault.
    If the compressor is hot then it’s not a DIY repair sorry for the bad news.
    Bob
    #427416
    smandoob
    Ok, understood.
    Many thanks for your advice Bob.
