LG GWL2227HSYA FRIDGE PUMP
  • #80706
    Appliance details: GWl2227HSYA, 910WRHR00374, TAB34629119
    We ordered a pump from connect LGEAHA72909001 but engineer advises hose connections on bottom are different – tried swapping base of pump over, but pump didn’t run
    Is there any tech advice available from LG, is there a fitting kit?
    Thanks,
    Alister
    #413801
    SAMURI
    Re: LG GWL2227HSYA FRIDGE PUMP
    Normally a strait swop you have to take out the water solinoid valve to fit.
    Not much room to fit but I have never found a problem with the size of the pipes.
    If connect supplied the part they should be able to let you no if there is any mod kits.
    Bob
