Not making ice. No water coming through to ice tray.
Although the water dispenser for drinking is ok.
Have checked the valves both ok
Test switch in ice maker not operating , Checking the connections on the main pcb the switch does open and close.
Icemaker Stop switch reading ok
Ice maker motor reading ok
Hall IC & Ice maker sensor no resistance reading, is this normal?
I have noticed that the water pipe to the icemaker runs through the door, could this pipe be kinked or frozen. Any suggestions.
however, if it was kinked, it would never have worked, and if it was frozen, the water feed pipe would be frozen too
its usually the ice maker tbhhave you checked the plug in the door, where its plugged in? sometimes it comes loose, and its a pig to get to, but its worth checking first
however, ive had one of late that had an ice maker, pcb, and a new door, and it just wouldnt work.
