Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LG Intellowasher
- This topic has 10 replies, 7 voices, and was last updated 20 years, 10 months ago by
admin.
June 9, 2005 at 9:30 am #10025
KeymasterHi.. can you help? Our washing machine seems to be leaking water with every wash and it seems to be coming from the powder drawer. We have taken it out and tried to check where and why its happening but no joy yet. Can you recommend and engineer to come out if it is necessary?
ThanksJune 9, 2005 at 10:01 am #137870Goatboy
ParticipantRe: LG Intellowasher
http://www.ukwhitegoods.co.uk/modules.p … whitegoods
Click the link above for a repair.
We could do with a little more info. How old is the machine, or what is it’s model number? When is the water coming out of the soap-box? Contantly? During the rinses? When it’s filling? When it’s spinning?
June 9, 2005 at 10:44 am #137871admin
KeymasterRe: LG Intellowasher
Hi.. the machine was bought in Feb 03 which makes it just over 2 years old and not eligible for any warrenty. It is a model WM1480FHD. The soap is coming out of the soap box/dispenser we think and when it is washing.. we can see it running down the left hand side when the washing is on.
Hope thats enough info!
ThanksJune 9, 2005 at 11:01 am #137872admin
hi,
These soap boxes are well known for leaks, you will need a replacement dispensor. There are two but 4925ER1002D can be converted to fit either application approx price £20.00 plus vat plus fitting.
KevinJune 9, 2005 at 11:06 am #137873Dave_Conway
If you read this thread:
http://www.ukwhitegoods.co.uk/modules.p … pic&t=5952
Pretty much the same problem 😉
dave.
June 9, 2005 at 6:49 pm #137874DentedPorsche
Had a couple of these (and a few Samsungs with a sock stuck between the drums at the dispenser hose.
Check there’s no blockage where the dispenser hose fits the outer tub.DP
November 21, 2005 at 1:34 am #137875hilda
Guten Tag
I have problem with the LG Intellowasher, It is no longer function correctly , The unit will not empty of the wasser anz more Mein Gatte has make the check to see the under wash basin outlet and this let some wasser out not much , We have to use small pipe located at the lower left side is small pipe attached to pump filter . We hear no sound from the pump the unit is only able to empty in the manual fashion this is emergency pipe? bitte I am unaware of the correct englisch name for this.
I am living in the UK, I will not make the mistake again I buy Deutsch next time.
LG Intellowasher 34WD4880 it has dry function also? big ha ha is not so good.
What is to be done ? We make check for obstruction in Pump filter there is not appearing. Is this a common fault? Is there anythings to look at also. bitte you make list to do things. Ja This is most inconvenient I like help it is nice to get this and make happy Frau .. Dank.
November 21, 2005 at 3:01 pm #137876admin
hi hilda
the most probable couse is either a blocked pump or hose assembly or that the pump has failed.if you have tried to clear the pump then it may need a engineer visit.
please look in the repairs@ section to find an engineer
bryan
December 9, 2007 at 8:59 pm #137877hilda
I have solution to my problem is Elasticated band in pump. I remove it is work OK.
I now have other different problem. When machine go to spin it is make clungk grate noise und is vibrations very much it does not achieve correct velocity it is like something is inside drum Do I need neu washing machine? or is this fix possibleFroehliche Weihnachten
December 10, 2007 at 7:36 pm #137878iadom
ModeratorRe: LG Intellowasher
Can any of the LG specialists help Hilda?
It sounds rather poorly to me, 😥
December 12, 2007 at 1:31 am #137879candyking
Hi Hilda, you will have to determine whether there is something in between the drum and the tub, one of the most common culprits is the wires from bras geting lost in machine. if you think this is possible then you may manage to retrieve this through one of the holes in the drum (if one end happens to be sticking through) or through the heater apperture.
BUT PLEASE MAKE SURE THAT THE APPLIANCE IS UNPLUGGED BEFORE DOING ANYTHING.
The other possibillity is that the bearings have failed, this is not entirely uncommon and is fairly serious, if you are lucky the drum shaft may not need replacing with a resulting cost in the £100 region, and maybe £50 more if the drum shaft req replacing also.
I hope this helps a little, if i had a little more detail about noise i could possibly have given you a bit more info.
John
