LG Intellowasher DD 7kg load
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG Intellowasher DD 7kg load
  • #32167
    windyone
    Hi, I’ve also been given an LG Intellowasher model WM1480 FHD.
    I’ve been told the bearings are going. Can anyone tell me if I can still get this part please, and if, in general terms this is straightforward or a bugger of a job :clown:
    thanks,
    Windyone
    #233883
    helo_75
    yep the bearings are available
    no its not easy, especially since its a direct drive
    probably worth it, as long as the drum shaft aint worn
    id get someone in to do it, not the easiest of tasks
    #233884
    windyone
    Re: LG Intellowasher DD 7kg load
    That’s much appreciated..I was going to get someone to do it..my husband 😀 but he doesn’t fancy a bugger of a job, so I’ll attempt to take it apart.
    If I can do that, then he will put it together again, rather than have it lying around on the garage floor.
    He’s got a bearing puller/pusher etc.
    Onward and upward!
