I have a lg wd-1050fhb and intermitantly it will stop and display the error code TE. The manual gives no clue to this fault just says call for service. Any advice would be much appreciated.
hi rustyboy,
it a thermistor error, engineer time i think,
please check your guarantee as you might still be covered as some lg appliances have a 5 year guarantee. 😀
disconnect it from the supply if you are having a look yourself.
Bob.
Thanks for the info. had a look and found that the connector to the thermostat had got wet at some point and was corroded, I cleaned it up and now seems to be working ok.
