LG NO SPIN
  • #64413
    LittleMan
    Customer phoned and said her LG washing machine would not spin and the unbalance warning comes on even when they do a wash empty
    they have no mod number.I havent worked on meny LG machines is this a common fault and how do i repair it. Thanks
    Les
    #357020
    QUICK FIX
    Re: LG NO SPIN
    could be pcb depends if direct drive or not.more likely pcb picking up a fault not there if it has a motor just check tacho connections bad for loose wires take it off and check
    #357021
    LittleMan
    Re: LG NO SPIN
    Thanks for that. Went today found to be dog hair in pump left machine working . Do the LG pumps stop and start on the spin.
    Thanks Les
    #357022
    QUICK FIX
    Re: LG NO SPIN
    usually you get oe as the fault you do get the pumps running then sticking have channged a few recently all about 5-6 years old
