Re: LG pump not always starting
Yes, I did exactly the same, buzzing so you think the pump has stalled but if you disconnect the pump you still hear the buzzing. I think it’s a dodgy relay on the main module but I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain. In my case I priced up a new module which was £130 IIRC. I told the customer I could not do the repair as I would not have been able to return the new module if it didn’t cure the fault. 🙁
