Re: LG RC8003a TE3 fault
tE 1 Low temperature thermistor open
tE 2 Low temperature thermistor short
tE 3 High temperature thermistor open
tE 4 High temperature thermistor short
tE1 : Check the main PCB red 4 pin housing not inserting Blue harness in red 4 pin
( number 2 , 4 )
Low temperature thermistor connector not inserting
Main PCB Micom not soldering replace Main PCB
tE2 : Check the main PCB red 4 pin housing Short of Blue harness in Red 4 pin.
Low temperature thermistor short : check the resitance.
tE3 : Check the white 8 pin housing (No. 3,4) in main PCB.
And Check the high temperature thermistor connector in rear cover part. ( blue wire )
tE4 : Check the main PCB White 8 pin housing.
Short of Blue harness in White 8 pin.
High temperature thermistor short : check the resitance.
Main PCB Micom short replace Main PCB.
EHE (ELE ) (Heater if memory serves me corretly)
Case 1. When break out or irregular current occurs.
– After removing ELB Connector, operate full time 1Cycle.
Case 2. EHE (ELE) message expresses continuously because of aging items.
– Change the old items.
be LED display “be ” in case of belt broken or pressed the micro switch by Motor bracket.
Hope this helps. 😀
