My LG RC 2011A condenser tumble dryer, which is 2 years old and never been a problem, has started to leak underneath from the back of the condenser unit this started after I moved the machine for cleaning. All parts, filters etc are clean and clear, and regularly serviced, air flow is good, temperatures are fine.The pump is working and most of the water is discharged as usual but the leak is enough to produce a small pool. Any ideas would be gratefully received, I’m baffled and wondering whether it might need a new condenser?
Kind regards
David
