I want to replace the door seal on our machine but comes up with two seals “with tube seal” with out seal so not sure which I need. The only diffrance I can see in the two pics is a small tube on the bottom of the seal. Lg f1256qd is our model
If you have a tiny drain hole at the bottom of the seal then this is the one with tube. You have to look carefully as it is only very small. (fold back the seal, right at the bottom)
