Lg showing fault code oe
Home Forums Public Support Forums General Enquiries And Questions Lg showing fault code oe
  • #94207
    Richloadslew
    Lg f14u1fcn8/01 fully automatic washing machine. No kinks in discharge pipe, filter all clean. Changed discharge water pump. Still same oe code?? Anybody with any now how after these cheers.
    #456708
    Re: Lg showing fault code oe
    Outlet Error is the code meaning so, all it means is that the machine cannot detect that it has drained, not necessarily that it has not physically drained.
    So it can be a pressure sensor issue, blockage to the pressure sensor or something more malign in the electronics that is causing it not to recognise that the machine has emptied.
    zibit
    kwatt has explained that very nicely
