Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › lg side by side duct door replacement. gwl227ybqa
- This topic has 20 replies, 4 voices, and was last updated 12 years, 10 months ago by
sweeneyuk.
May 30, 2013 at 7:37 pm #75655
sweeneyuk
ParticipantMy Lg is not dispensing ice and seems the duct door is failing to open.
i can see where to buy replacement part but cannot fugure how to get into door behind the display assembly.
does anyone know where we can view service manuals and not just owner manuals or if someone knows how to get remove the assembly it will be much appreciated.
May 30, 2013 at 10:45 pm #395747kwatt
KeymasterRe: lg side by side duct door replacement. gwl227ybqa
Usually you just have to work it out. 🙁
I’m not sure how you get into the LG ones but what part is it that you think is faulty?
May 31, 2013 at 4:03 pm #395748sweeneyuk
ParticipantRe: lg side by side duct door replacement. gwl227ybqa
worked it out and discovered the duct cap assembly has broken off where it attaches to the solenoid to open it. now just need the replacement part.
May 31, 2013 at 4:05 pm #395749kwatt
What part though? 😉
May 31, 2013 at 4:19 pm #395750sweeneyuk
the duct cap assembly see link
http://www.4lg.co.uk/duct-cap-assembly/ … gwl227ybqaMay 31, 2013 at 4:31 pm #395751kwatt
You are aware that there are two used on that model dependant on the production date don’t you? That one being the earlier version.
And that if you asked, we could supply that for about £10 less, if not more.
May 31, 2013 at 4:45 pm #395752sweeneyuk
no i didnt and didnt know you were a supplier. if i got the wrong one ill send it back and be in touch. had a rare moment of free time last night and today and wanted it sorted as its been broken for over a year now. its approx 4 years old so hope i got the right one. cheers
May 31, 2013 at 4:48 pm #395753kwatt
Yup and, usually cheaper. 😉
That one is now here: http://shop.ukwhitegoods.co.uk/5007ja30 … enser-flap
May 31, 2013 at 5:03 pm #395754sweeneyuk
will bear in mind for other items in future. thanks
June 6, 2013 at 1:58 pm #395755sweeneyuk
hello kwatt, hope you see this post. the replacement duct door came and was the correct part, however, its still not working. as far as i can tell the actuator or solenoid that operates the door doesn’t work. its like an electromagnet that pulls a shaft back when activated or at least thats what it looks like. this shaft is not moving at all when switched on and so not opening the door.
Do you have any suggestions on where to get the replacement or to check if its def this part and not the supply to it.
any help appreciated. thanks in advance.June 6, 2013 at 2:06 pm #395756sweeneyuk
this the offending item, the silver is very stiff inside the actuator and can only presume that it should release easy or the duct door will not shut.
IMAG0531 by sweeneyuk567, on FlickrJune 6, 2013 at 2:18 pm #395757kwatt
The flap should only open when the machine wants to dump ice out and I would imagine that this would be controlled by a relay, probably on a PCB somewhere.
Is it making ice at all?
Does it dispense water okay?
That part would look to be the solenoid and it could be faulty but you can test it has a circuit with a multimeter, if it’s open circuit then it’s had it. That’s the actual electrical part that pulls the flap open using a magnetic field, it has no brains at all.
Scanning the tech on the model though there are any number of things that could cause the fridge freezer not to dispense ice, such as a failed ice sensor, ice maker issues and so on.
June 6, 2013 at 6:47 pm #395758sweeneyuk
thanks for advice. it makes ice and tries to dispense it but duct door is not opening. when i saw the plastic lug had snapped off where it engages this solenoid i thought it would just be that and so relplaced it. water and everything else is fine. tried to operate with it all wired up so i could watch if the solenoid was working but the shaft doesnt move. i thought that the shaft would need to move freeley inside the solenoid for magnetic field to draw back the shaft and for the duct door spring to pull shaft back out as it closed and sealed the freezer again. i cant believe this solenoid would allow it as i need to use pliers to move it in and out.
in order to test the solenoid should i measure the resistance across its terminals?
thanks again for help.ive also tried to locate this solenoid on your parts section, sent an email as i couldnt see it there.
June 6, 2013 at 6:55 pm #395759kwatt
Yes, it will either be open or closed circuit.
Dave will add the part for you and it’s not there because it’s something we’ve never been asked for before. To be fair it’s the first I’ve come across that problem.
June 6, 2013 at 8:59 pm #395760sweeneyuk
Am I right in thinking the shaft should operate freely back and forth? Want to be sure before I spend more as if this don’t solve it then I’ll have to pay an engineer or leave it. It’s just bugged me that it broke as soon as the warranty ran out and we bought it from comet.
