LG side by side, freezer not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum LG side by side, freezer not cooling
  • #63479
    CPF
    Model GWB227YUQA
    The freezer (and by extension the fridge also) on the above model is not cooling. The appliance sounds like it is working, fan on bottom rear is turning, compressor is hot.
    I took off the panel inside freezer side, the evaporator coil had no ice on it.
    I would be grateful for any suggestions that I could try before shelling out for a professional.
    #353893
    spimps
    Re: LG side by side, freezer not cooling
    If compressor is running ,hot and no refigeration likely there is a refigerant leak somewhere on the system,could also be compressor less likely a system blockage.
    You can search on here for your nearest engineer.
