LG Solid Base machines
  • #75900
    timdowning
    What’s the best way to get to the drain pump on these LG’s
    with a solid plastic base? Is it front off? Couldn’t see how the front comes off & didn’t want to force anything.
    Ta.
    #396532
    QUICK FIX
    Re: LG Solid Base machines
    take small front panel off and tilt machine back you slacken the 2 front panel screws it is tricky but im used to it or its lid off facia and front panel depends if pump unit is front left or front right
    #396533
    keithwilliams
    yes i agree you can get at it through behind the plynth. loosen it from the base and then carefully twist it around with pipes attached and unscrew the pump motor.
