Re: LG SxS FR/FRZ GWL207 Leaking
If it is leaking have you checked the fitting under the kick plate at the front.
If it is leaking from the pipe it self near the bottom of the door and it is too short to join with a push fit connector then a new door is required as the pipe is foamed in.
The most likely place for a leak is the connector at the bottom the pipe can sometimes break as it enters the connector near the protection spring over the pipe on the more recent models.
Bob
