LG TD-C70040E Tumble dryer problem? (wont dry)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG TD-C70040E Tumble dryer problem? (wont dry)
  • #58055
    vito
    It doesent dry clothes good. When i put clothes inside and display said 2 hours time. It start and maybe about after 30min display count like 30min time left, and clothes are not dry.
    There is text display: dry, iron dry, cupboard dry. When i start machine light blinks in dry option about 2 minutes, and then it goes to the cupboard dry and blinks there all time before the cooling session.
    I have cleaned every place and there is brand new heater also. Any idea what might be a problem?
    Heater works normally, it really get hot but program/timer count too fast.
    This is sensor dry model, but where is the sensors?
    Thank you!
    #333238
    vito
    Re: LG TD-C70040E Tumble dryer problem? (wont dry)
    I think that two relay are broken in pcb board. But how i can change, because that hole pcb board is glued in silicon mass?
    #333239
    Bill
    First i would check that the condenser is clean, I mean very clean in both directions. This advice is coming to you from a
    retired L.G. engineer/tech.
    Bill Ellis
    #333240
    vito
    I have checked that and in sideways light not goes very good trough. But i have washed that and also cleanit with pressure air.
    And im thinkg if that condenser is stucked why program goes too fast? I think if that is stucked program takes longtime to dry because dry sensors tells that there is moisture.
    #333241
    Bill
    Vito
    I still sounds like the condesor as it is not condensing correctly. You say it is in a cupboard, this is not a good idea as you need cooler air around the machine for it to work at its best, yes I know it has been in there for some time but as it gets a bit older the condensor clogs up wee bity.
    Bill :scot:
    #333242
    vito
    I mean when i start machine there is display what shows where program goes.
    dry, iron dry cupboard dry, cooling.
    When machine starts light blinks in dry section about 2 minutes, then program jumps over iron dry section to the cupboard dry.
    #333243
    vito
    If i try that machine without condenser, is that possible?
    And is there betterways to clean that condenser than air?
    #333244
    vito
    it was dry sensor fault. I put it wet damp to the sensors and its works normally. Now i have to find out how to change those sensors..
    #333245
    vito
    I think Bill you were right, condesner was the problem. Also i run factory settings to the machine. It works now perfectly. I have figured that if you put too little clothes to drum, sensors dont work correctly that is feature.
    Thank you Bill.
