LG TD-C70045E Clean Filter error but filters are clean
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum LG TD-C70045E Clean Filter error but filters are clean
  • #84251
    Okit
    Hi. My LG tumble dryer stopped mid cycle recently with ‘Clean filter’ error. There was also a faint smell of burning. Our filters are clean.
    Here’s what I did to attempt to solve it – BUT it did not fix the problem. The dryer runs and heats for 2 to 3 minutes then stops with the beeper and ‘clean filter error:
    I removed rear fan and heater cover to reset the trip button but that did not resolve it.
    I then removed the top, both sides and front panels (including door and the switch panel. The inside was surprisingly clean.
    I also removed the housing of the first fan before the electric motor (again quite clean inside).
    I cleaned all airways, the blades on both fans, the filters and the sensor under the bottom door filter (which was a little gunky but now shines!). I removed the little fluff around the inside of the unit on ledges. Then reassembled BUT it still cuts out after 2 to 3 minutes with ‘clean filter’ error.
    What have I missed or what parts do I need to replace please?
    e
    #425204
    Okit
    Re: LG TD-C70045E Clean Filter error but filters are clean
    do you think it might be the thermostat / cut-out on the heater?
    The red button is down and has a little play.
    How about the thermostat to the door?
    Just wondering if a fault here might trigger the ‘clean filter’ error
