LG TD-C70045E Condenser Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG TD-C70045E Condenser Dryer
  • #36904
    benmunashe
    I have a dryer of the model above that started displaying what I assume to be an error code ‘EHE’ I am seeking help as to what may need doing. The drum sounds as if it turns once then the code appears and nothing else happens.
    #252746
    helo_75
    Case 1. When black out or irregular current occurs.
    – After removing ELB Connector, operate full time 1Cycle.
    Case 2. EHE (ELE) message expresses continuously because of aging items.
    – Change the old items.
    thats what the lg manual says
    not much help really
    id try a capacitor myself (10uf)
    #252747
    benmunashe
    Re: LG TD-C70045E Condenser Dryer
    Thank you for your response but I am just a lay person. Could you simplify some of the technical terms you used or explain where the components are found etc
    Lucky Goldstar
