I am trying to establish if the motor is the fault on an LG TD-C70045E. The fault presented itself as continued clean filter warning and hot smell when trying to use machine.
Steps taken so far:
– removed back and confirmed motor not turning, motor turns freely by hand.
– tested capacitor, reads 10uF which matches rating on casing.
– removed belt and motor still doesn’t turn unloaded.
– motor has 3 connectors on it, I’m getting around 45 ohms between the outer two, but nothing between the middle and either outer connection.
Motor is 4861EL1003A.
I’d appreciate any guidance on whether it is the motor or if I need to do anything else to diagnose it.
Regards
Wayne
