Hi gents
have an LG TDC70045e that wont start as it is flashing clean filter & start noen thought it was pump sump full off water emptied it, pump does work ok any ideas as machine failed again chees alro
Re: LG TDC70045e flashing clean filter &start noen
Thanx for reply fitted new cap.But the t/d had new cap & motor in feb 11, t/d after pressing start button a few times started then watch it run for about 30mins then it went to END finished well before it should of,tried to set on again but will not start(just start & clean filter flashing) start button feels as tho its making but no go any one got tech on this as suspect pcb but display or main pcb????? cheers alro
I’ve had the start button faulty on these machines that have had heavy use.!
What Ive done was to unsolder one of the other buttons on the display that is not used
By the customer and replace the start button with that one and re placed other one taken back Into its place.(much cheaper than a new board)
Are the clothes wet that you have tried to dry.?
Any blockages?
