LG TDC70045E HELP
  • #30899
    bulldog
    i have got a LG mod tdc70045e which has a fault the motor gets very hot
    and only turns the drum half a turn and seems to semi seize and when it is switched off in stand by mode the drum seems to be juddering and trying 2 turn can you help with this fault please many thanks
    bulldog
    #228855
    whitevanman
    Re: LG TDC70045E HELP
    main pcb required.
    hope this helps
    Wvm
    #228856
    candyking
    Hi, capacitors fail on these , got to be worth a punt i’d say.
