Lg tumble cuts out
  • #89306
    kaibart
    Hi all just wondering if any has any ideas where to start looking on a lg condenser dryer (haven’t got model no ) it works for 20 mins then cuts out think it could be a sensor but have never worked on 1 so any help appreciated cheers Kai
    #440960
    jimca007
    Re: Lg tumble cuts out
    could be pump failure, they’re very prone to the lift pumps gunging up.
    #440961
    kaibart
    Ok cheers will check the pump
    #440962
    Martin114
    I had one of these with same fault a while back and it turned out to be the motor toc. new motor cured it.
    #440963
    kaibart
    Ok cheers Martin will check that as well
    #440964
    kaibart
    Found the problem to be display board well wires to it resolver got working fine
