Lg tumble dryer Mod C70045E
  • #34346
    ray.t
    any help or advice would be very welcome.
    Many thanks, Ray.T
    #242219
    bazza500
    Re: Lg tumble dryer Mod C70045E
    on what?
    What`s the symptoms etc…
    #242220
    ray.t
    Sorry, this didn’t come out very well. Fault was “no heat” I reset tripped stat on heater. Worked fine. Been back today. Fault is now, when prog selected and start switch pressed, after about 15secs, pump starts, but drum not turning. After a further 15 secs “Clean filter” and “dry” lights flash and starts beeping. Changed capacitor. No change. On first call and today checked filter and condenser. All OK
    Any helpor advice would be very gratefully received.
    Thanks very much Ray.t
    #242221
    bazza500
    I have had this fault before.
    Check the motor windings. There is a TOC in them that goes open CCT and causes these symptoms.
    #242222
    ray.t
    Thanks for your prompt reply. Is this TOC resetable or does it mean a new motor. If so have you any idea of cost? Thanks again. Ray.t
    #242223
    bazza500
    New motor I`m afraid 🙁
    rrp £112 ish
    #242224
    ray.t
    Thanks very much Bazza. I’ll go and check the motor and then give her the good news. Cheers. Ray.t
    Lucky Goldstar
