SWITCH ON,
MOTOR
TURNS OFF AND
THE ALARM
SOUNDS
1. The dust bin is full.
2. The rotating blade in the dust
bin is restricted by an obstacle.
3. The dust bin is in the wrong
position.
1. Turn off the vacuum and empty the dust bin.
2. Turn off the vacuum and remove the obstacle
from the dust bin.
3. Turn off the vacuum and reattach the dust bin in
the correct position.
cheers for that but nothing there, only thing i can see is when the bin is removed theres a spring below the bin on the vac that is loose not sure what it does
