LG w/m displaying pe
  • #36615
    jof
    Have got an LG WM1350 w/m that is coming up with the error code pe have not seen this fault before can anyone help me out?
    Thanks 🙂
    #251692
    helo_75
    PE – the sensor pressure switch is out of order
    according to my manual anyway
    hope this helps?
    #251693
    Re: LG w/m displaying pe
    jof wrote:Have got an LG WM1350 w/m that is coming up with the error code pe have not seen this fault before can anyone help me out?
    Thanks 🙂
    Its on the very first page of the Known Error codes thread. 😉
    Welcome to the madhouse jof. 😀
    jof
    What does this look like and where is it suituated?
    Many thanks 🙂
    #251695
    helo_75
    its an analogic switch, and will be at the top, near the pcb
    #251696
    Martin114
    most likely a blockage in the tube at the bottom of the pressure swith pipe.
    #251697
    helo_75
    or a hole in the hose… always worth a look first!!!!!!!
    #251698
    jof
    have checked pipe for blockage as i have found a few before that had built up with slime. this caused the machine to over fill with water.
    So the part i need to check is what the vacum pipe is connected to?
    many thanks 🙂
    Lucky Goldstar
