LG wash element
  • #48435
    abbots
    hi,
    WM12380TB
    s. 509KWZH00253
    has any one got a part number for the heater please.
    cheers.
    john
    #296581
    Re: LG wash element
    Presumably you have seen the old one? If it’s the 2000w 300mm one as commonly used on the eight year old machines then a 2100w Hotpoint WM heater fits perfectly and is 1/3 the price.
    Mike.
    #296582
    abbots
    Re: LG wash element
    havent taken it out to measure it, and
    it has no connection for a thermister .
    it has two yellow coloured connectors which i suspect have a thermal fuse fitted .
    the pressure system was blocked and the heater was coming on when no water was in the tub.
    now the heater is open circuit.
    cheers.
    jk
    #296583
    Re: LG wash element
    😕 The HPT part has a thermal fuse in the element, you just leave the ntc unconnected. The LG will have its own ntc elsewhere. Are these yellow wires additional to the normal heater connections? If they go to a thermal fuse, it should be that that is o/c not the element 😕
    Mike.
    #296584
    abbots
    Re: LG wash element
    no,the yellow colour is just on the end of the actual element terminals.
    i wasn’t aware that the hotpoint element had a thermal fuse fited within the element terminals,so i will use one if i have too.
    is it not possible to get a genuine LG element from any where?
    thanks.
    john
    #296585
    Re: LG wash element
    Connect are the only reliable trade source I know of for LG parts. Seme were good but no longer much use. If you tap in “LG heater wash laundry” to connect’s search box it’ll give you some results to consider.
    You could ring them or e-mail to get confirmation of fit.
    Mike.
    #296586
    abbots
    Re: LG wash element
    cheers mike.
    john
