First of all welcome to all ,
I have a F1403RD LG washer dryer but the dryer has suddenly stopped heating up. At first I would get error DHE roughly on 19 minutes into a 30 minute dry. After the error I replaced the dryer element and the Thermister dryer sensor the 2 prong job with parts from 4lg. I didn’t replace the Thermostat in the metal dryer duct so could it possible be this? also, how do I test this ?.
It still doesn’t heat up on dry but the DHE error doesn’t appear and now it goes to the end of the cycle as normal but cold. I also took the plastic vent dryer duct off the back of the tub and cleaned it out but there wasn’t much in it as I had cleaned this about a year back.
I’m now at a loss as to what the problem can be. How do I now check to find out what’s causing the error ? any fuses or blocked pipes I should look for ?
Any help would be greatly appreciated.
thanks
