Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LG Washer emtying through door.
- This topic has 5 replies, 2 voices, and was last updated 19 years, 5 months ago by
tenbob.
November 28, 2006 at 10:30 am #22922
tenbob
ParticipantHi, It has done this twice each time we have stopped it and finished emtying it via the filter, after the firt time it worked ok for 6 washers now it has done it again. The door seal seems fine. Advice most welcome. Thanks 😥
November 29, 2006 at 1:21 am #196542Penguin45
ParticipantRe: LG Washer emtying through door.
Does the pump actually run? Select “spin” only and see what happens. If you can hear the pump whirring away, you’ve got a blockage somewhere. If you can’t, the pump itself may be jammed (propellor, behind the filter) or failed.
Penguin45.November 30, 2006 at 12:23 pm #196543tenbob
Hi Penquin45. Since i posted wy wife has done 6 washers without a problem, we did what you said this morning and the pump worked fine. It must be hard for you to diagnose with it only happening now then and not seeing it happen. I really appreciate your help.Cheers Tenbob.
December 1, 2006 at 9:03 am #196544tenbob
Hi, Just watched the washer and water coming out of the powder drawer not the door!!! 😳 Cheers Tenbob.
December 2, 2006 at 1:05 am #196545Penguin45
There was an issue with LG soap drawers leaking. Initial fix was to try and seal the front row of holes in the box top. There is now a replacement box available, which should solve the problem. I don’t have the LG tech info, so post a link to this thread to spares@ukwhitegoods.co.uk and they should be able to get you a replacement.
Penguin45.December 2, 2006 at 10:22 am #196546tenbob
Penguin45 wrote:There was an issue with LG soap drawers leaking. Initial fix was to try and seal the front row of holes in the box top. There is now a replacement box available, which should solve the problem. I don’t have the LG tech info, so post a link to this thread to spares@ukwhitegoods.co.uk and they should be able to get you a replacement.
Penguin45. Much appreciated Penquin45, All the best Tenbob. 😀 -
