LG washer error code. Help
  • #9018
    grooster
    Just been out to an LG washer WD 1243 FH that flashes up EO after its been on a while. I can put it on a quick wash and it goes through ok. Does anybody have any idea on this.
    Thanks for your help guys.
    #131723
    Re: LG washer error code. Help
    hi,
    OE is not draining in 10 minutes…..its a universal pump (pmp999) askol.
    The filters also let small objects through to jam the impellor.
    The lower kickplate removes to allow access to the front panel screws for easy access.
    Kevin
    #131724
    grooster
    Cheers Kevin
    Thanks for the info, i’ll give it a go now.
    #131725
    Bill
    💡 Looked up in the LG bookie that I have and you are correct. I have had an elastic band in the pump before now!
    Bill
