LG WASHER WM-1285FHD
  • #27252
    mjw1208
    Does anybody know any common faults with these ?,
    have to look at one for a friend who says it went pop then nothing he then despatched it to his garage in disgust as its about 2 year old .
    is there any known faults to look for and is spares available and from where ?
    #213226
    mjw1208
    Re: LG WASHER WM-1285FHD
    further to my previous post have tried the machine and does as follows-
    connect up and switch on set programme and start – starts to fill and drum starts spinning (with slight screeching noise ) goes approx 2minutes then int. stops ,display shows symptom code LE (overload in motor)
    any suggestions would be helpful
    #213227
    BobHope
    hi mjw1208
    check the direct drive stator plug and socket for corrosion and water ingress caused by a leaking drum support shaft seal, if thats ok its the stator itself or the hall effect sensor which is part of the stator.
    Bob.
    #213228
    mjw1208
    thanks for that , no sign of corrosion but have checked plugs and socket plus cleaned / tightened but no improvement overall ,
    seems it may be destined for the scrap heap as cost to replace parts may be too expensive
