Hi chaps
I have an LG washing machine(sorry no model No.) where the drain pump will not run. We get an error code SE come up straight away.
I have run the diagnostic prog and the pump runs…also the main motor runs up ok.
When I test for voltage at pump I get <24v.Have checked back to main board and voltage same there.
Any info or quick fix I would be happy to have.
I have looked at code in UK white Goods codes, and it says it is either a motor problem or PCB???
regards Trev. 😥
